jayhar
en respuesta a: rickKVK8F
issue you're facing is not uncommon and can stem from various causes such as corrupted settings, misconfigured software, or conflicts with system resources.
1. Create a new profile in AutoCAD (Options > Profiles)
2. Too many fonts are installed in system
3. Repair the drawing file (see How to repair corrupt AutoCAD files).
4. Type GRAPHICSCONFIG in the Command Line.
  • Turn off Hardware Acceleration and test again.
  • Update your graphics card drivers and ensure compatibility with AutoCAD 2025.
5. Sometimes AutoCAD crashes if system resources (CPU, RAM, etc.) are low or overloaded.
6. Purge unnecessary objects from the drawing
     Repair the drawing file using the "Audit" command
also follow instruction of @paullimapa
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
