- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
ACAD2025 crashed when double clicking mtext or text
Hi. Just recently autocad has started crashing when double clicking on Mtext or text. Attached are the crash logs. The *.pb files are not supported by this forum so i have zipped the up.
Once i restart autocad the double click on text is fine. It's frustrating as it catches me everytime.
AutoCAD whon't shut down and i have to use Task Manager to end the process before i can restart it.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I assume you've installed 2025.1.1 update?
Have you tried Resetting AutoCAD?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
issue you're facing is not uncommon and can stem from various causes such as corrupted settings, misconfigured software, or conflicts with system resources.
1. Create a new profile in AutoCAD (Options > Profiles)
2. Too many fonts are installed in system
3. Repair the drawing file (see How to repair corrupt AutoCAD files).
4. Type GRAPHICSCONFIG in the Command Line.
- Turn off Hardware Acceleration and test again.
- Update your graphics card drivers and ensure compatibility with AutoCAD 2025.
5. Sometimes AutoCAD crashes if system resources (CPU, RAM, etc.) are low or overloaded.
6. Purge unnecessary objects from the drawing
also follow instruction of @paullimapa
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Just update windows and installed 2025.12.1 and now autocad wont even open. I should have just put up with the occassional crash.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks Jayhar. When i get access to AutoCAD again i'll try this. Looks like it'll be an uninstall and reinstall job now.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
"Unable to run AutoCAD. A dependent component Microsoft .NET is missing..." when launching AutoCAD products
