- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Why do you not know which font type you are unsing?
Select a (M)Text, check out the STYLE setting, open this style (command STYLE, seleect the one and [Change], check out the used font,
you will see some fonts with a TT Symbol (TrueType) and some with another Symbol (SHX).
You are using TT as pendean stated before, the the answer is: Read my post above again!
Start PLOT command, select your printer, press the [Properties...] button right of the printer name
and follow my Screenshot above, change this setting to what I highlighted.
Q: Are you using the windows driver directly, or are you using a .pc3 file ?
Because if you want to change it, you (have to) create a .pc3 file and you have to use it in future (because the setting is stored in this file)
Sebastian
