RobertMyb
en respuesta a: cadffm
Hi @cadffm
Thanks for replying.
I am actually not sure which fonts are which, to be honest, but I think it is True Type.
So I did set the true type as text and it worked, but only if I print from model space or print from the default page layouts ('Layout1" and Layout2" that appears when you open a drawing). It still does not work if I print from an inserted drawing template (.dwt) that I have setup for different drawing types. I have setup the plot style the same as what I did when I printed from model space or the default page layouts, but the PDF's are still not searchable. Only if I print from model space or default layouts.
I need it to work from my setup layouts. Can you help me with this?
I attached a dwg of one page from the manual and one default layout and one setup layout. I just removed all logos and company information.
