Thanks for posting this.  I ran into this problem on a new DWG file recently.  How the problem occurred was, I used the WBLOCK command to extract linework from a drawing with modelspace split into 2 viewports.  When I opened the new block, the linework was on the left half of the view area, and the right half was just "dead" - no viewcube, and no way to interact with that side of the screen.  So it was like having 2 viewports, but not quite.
Using the +VPORTS command and selecting "Single" did not fix the problem.  But selecting 2 or more viewports, and then setting it back to single, did fix it.  This worked from both the +VPORTS command, and the View menu.
