- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Number Reversal Issue in AutoCAD 2025 - Request for Help
Hello everyone,
I'm experiencing an issue in AutoCAD 2025 where the numbers I type appear reversed and mirrored. For example, when I type 12345678, it displays as 87654321. This problem occurs with all numbers.
Attached is an image illustrating the issue.
I would greatly appreciate any assistance in resolving this problem. Thank you for your help.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
try this: Turn DX12 support off
Type in: GFXDX12<enter>0<enter>
(perhaps, restart is needed)
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hello
I hope this message finds you well.
I received instructions to turn off DX12 support in AutoCAD by typing in the following command:
However, I'm having difficulty following these steps. Could you please provide a detailed explanation of how to perform this action?
Thank you for your assistance.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
okay, no problem
Make sure you have one AutoCAD instance open only
"Type in GFXDX12<enter>0<enter>" means:
in AutoCAD
On your keyboard: Search and press the [ESC]key, press [ESC] key again
Search and press the [G]key
Search and press the [F]key
Search and press the [X]key
Search and press the [D]key
Search and press the [1]key
Search and press the [2]key
Search and press the [SPACE] or [ENTER] key
Search and press the number [0]key
Close AutoCAD
Open AutoCAD
Check the issue now again
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@ithreadsa3 wrote:...However, I'm having difficulty following these steps...
Friend, just type GFXDX12 at the command line, tap the keyboard button labelled <enter> to activate it, type 0 (that's a zero) then tap the keyboard button labelled <enter> to activate it. Now QSAVE your drawing (there is a button for that or you could type it at the command line, don't forget to activate it with the keyboard button labelled <enter>), then close and restart your AutoCAD 2025 for that change to take effect. See if that fixes your issue.
Let us know if you are still stuck trying to use GFXDX12 command.
