Kent1Cooper
en respuesta a: ВeekeeCZ
@ВeekeeCZ wrote:
... how about to make it a command c:pf, then it could run with 'pf.
And what would you expect to happen if you typed in the command name PF without being in a command, and without a reference point?  If someone wanted a single-purpose command, for example one that would always and only start a LINE command perpendicular from something, that could be done.  But (pf) works for many other things, like MOVE or COPY displacements, the second point in a 2P Circle, the next segment in a Polyline, etc.
Kent Cooper, AIA
