pendean
en respuesta a: tpobrien14
@tpobrien14 wrote:
... the PNG file is just a snapshot of what the DWG. file looks like in AutoCAD for me.  Do you happen to know why this would be happening? ....
You'll have to share your actual DWG file here then, your PNG was not informative enough for a diagnosis.
@tpobrien14 wrote:
...the program that I am using to generate these images allows me to export them as both a PDF and a DWG. file - I run into this problem as I import the DWG... why this would be happening?
Try that other program's support to see what else it can do, from what you've shared here, it appears to be very limited. AutoCAD only imports what that program created as is, it make no changes somehow during the action of opening.
HTH
