11-14-2024
01:07 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-14-2024
01:07 PM
Thanks for the response! It is greatly appreciated. I understand that you will not be able to import a PDF. into CAD, but the program that I am using to generate these images allows me to export them as both a PDF and a DWG. file - I run into this problem as I import the DWG. file into AutoCAD; it does not appear in AutoCAD as it does in the the PDF. The PDF. file that was originally attached was generated from the program I used to make it; the PNG file is just a snapshot of what the DWG. file looks like in AutoCAD for me. Do you happen to know why this would be happening?
