Jason.Piercey
en respuesta a: jdBAM63
Current styles will always come along for the ride. May I suggest starting a "working drawing" that contains all the blocks to be redefined? Insert everything that needs to be reworked, then clean up layers, styles, regapps, etc.. Basically all of the bloat, or inconsistently named items, that are always a struggle to remove and aggravating when they keep reappearing.
I've used this method before and it sure helped. I then Wblocked them out into their respective files so I have a fresh start without all the baggage.
