paullimapa
en respuesta a: elisag23
for those dimensions where you added a 2nd value below these are the steps I took to correct them:
1. DIMEDIT > HOME and then select those dimensions
2. Double click one at a time on each of those Dimensions or run the TEXTEDIT command
3. Replace current entries (or CTRL+A to select all) with: <>\X200
<> = dimension value
\X = value placed on line below
Now the dimension line shows up.
Repeat on the other dimensions
Paul Li
IT Specialist
@The Office
