10-23-2024
02:40 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-23-2024
02:40 PM
I have seen some workaround regarding this.
If you type PAN at the command line and then complete the command, does the problem persist when you try to pan again?
If you type 3DORBIT and use that command doe the problem persist after ending that command?
If you start panning and then hold shift after you start panning and then let go of the mouse wheel does it start the pan?
Some have also suggested restoring settings to default.
CADnoob
