- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Mouse Wheel Pan Issue
So my issue seems to be unlike the others...
This has happened to me a few times in the past but a quick software reboot usually fixes my issue, until today.
Here is my issue:
Mouse wheel click is normally pan, awesome, love it. BUT when I click in and hold to pan, the second i release it rotates the viewcube around the current selected point. ie select sw iso on the cube, click/hold to pan, release after pan and the screen rotates 90 deg.
any help would be awesome.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Your secret year version of autoCAD is what please? And your OS?
and which mouse/driver is it?
I am not able to replicate your experience in AutoCAD 2022-23-24-25 here in Win10-Win11 for example.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Not holding shift or ctrl, just simply the mouse wheel pan (click/hold)
Running AutoCAD 2022 w/ CADWorx Plant 23
Windows 10 Enterprise (64-bit os, Intel(R) Xeon(R) W-2125 CPU @ 4.00GHz)
ProtoArc Mouse - Driver version 10.0.19041.1
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Does it happen with a different mouse? [I'm thinking a faulty/dirty wheel-button, e.g. registering again when released, or something....]
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@ryan.champis wrote:Happened before CADworx was in my repertoire.
Here are the ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
and
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Contacting-a-techn...
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I have seen some workaround regarding this.
If you type PAN at the command line and then complete the command, does the problem persist when you try to pan again?
If you type 3DORBIT and use that command doe the problem persist after ending that command?
If you start panning and then hold shift after you start panning and then let go of the mouse wheel does it start the pan?
Some have also suggested restoring settings to default.
CADnoob
