- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Dynamic input not switching dimensions with tab key
Hi, I recently upgraded from AutoCAD 2023 to AutoCAD 2024 and my functionality using Dynamic Input no longer allows me to press the tab key to switch dimensions. I have dynamic input enabled and DYNMODE is set to 3. I have tried other DYNMODE variables and those do not allow me to use TAB either. It works if I use the comma to switch dimensions but I want to use the tab key, using the comma hides object dimensions and defeats the purpose. It does not appear that this functionality has been removed, as the Dimension Input Settings dialog box still has a light bulb saying to "Press TAB to switch to the next dimension input field".
What am I missing here?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Or did you pick up a new laptop or keyboard by chance too?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
No changes on the hardware side. Attached is a video, at approximately 20 seconds is when I was hitting tab and the field was not changing. Then when I use the comma after entering my dimension I am able to enter the second dimension.
Here is a video link as well if you are more comfortable.
https://streamable.com/8naqv9
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You might also want to test with the variable GFXDX12 turned off too (a program restart is required for it to take effect).
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I already have GFXDX12 set to 0. Running it without CADWorx does indeed fix it, I assume I have to take it up with Hexagon at this point. Thank you for your help!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
HarveyEKP,
I was wondering did you get anywhere with Hexagon on this I just upgraded our system the other day and came across this issue.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi there, I have opened a ticket with Hexagon regarding this. In short, they told me "oh sorry, there is no solution. We will work on fixing this in CADWorx 2025."
Here are the details for my case:
Very disappointing.
