02-26-2016
06:04 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-26-2016
06:04 AM
To respond to your question, only workstation cards are certified by Autodesk. However, I've found the certification to be a joke the last few years at least, as even certified cards don't always work as expected or correctly and Autodesk doesn't stand by their certification.
I use computers with both pro and consumer cards and don't notice a difference between the two, although I do almost exclusively 2D work. If I were in your position, I'd get the gaming card I wanted. When you find one you like, you can ask on the forums if anyone else is using the same card and if it has any issues with AutoCAD.
Work: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
