- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
OLE edit requires "reset" and then resizing almost 75% of the time?
We use OLE's in a project. There are pretty simple excel charts pasted into the file. Occasionally the info inside needs edited and saved. Why when I simply change a word or number in a cell, the OLE often stretches wildly, and requires a "reset" and then even after the reset its resizes back up to its a larger than set size? I'ts as if I must re insert it every time? Kinda defeats the purpose. Occasionally it stays where it should not often tho.
Also off topic here, but is there a way to enter a one click text edit mode? I stumbled on what seemed to be something similar the other day but can't recall how. Share your text editing tips, I would be grateful. I'm trying to cut down on extra clicks and moves. Wrists are tied at the end of an ACAD day.
