- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
My problem is that when I draw something and then put dimensions to it it shows me reversed , for example if the actual dimension is 70 it shows me 07
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Welcome to the forum.
Take a look at the link:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I'm sorry but can you help me with pictures I didn't fully understand do you mean that I should write UCS and PLAN in the lower command bar in the drawing interface
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Type in the command line :
Command: UCS
Current ucs name: *WORLD*
Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis] <World>: w
Command: PLAN
Enter an option [Current ucs/Ucs/World] <Current>:
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I think I did as you said but nothing happened to the dimensions or should I do something extra or redraw the drawing or should I re-dimension it?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Yes .. after you make what i suggest make a new dimensions now and see if any changes ![]()
If it's NOT solved .. please attache your CAD dwg here.
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The same issue was resolved applying the suggestion from message 3 (above).
Emilio Valentin
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you, I tried it but it didn't work and this laptop is not mine. I might have a problem with my sister if I change the language forever ![]()
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
As you can see in below image .. every thing is OK!! I have do nothing,i've just open the drawing.
How about the solution in message 3 above?
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
So I think the problem is with the laptop itself, so when I send it to my professor it will be fine. Thank you
for responding and helping me
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Must be a language issue, since opening in Autodesk Viewer seems good.
Does the laptop use any other language other than English? If so, it may be the issue.
After changing the language, close and restart AutoCAD.
Emilio Valentin
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you also for responding to me and helping me when I have my own laptop I will do what you said ![]()
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
