trickyK3C2L
en respuesta a: Washingtonn
Hey matey thanks for the reply, I appreciate your time, just need help as I still cannot navigate this program lol.
In relation to the test you mentioned (Eratosthenes) to do this test, I have to assume a distant sun with parallel sun rays, and this is not what we experience here where we live, and assuming a parameter in a test without proof will just void the test immediately.
Both models work with his test as the flat earth has a local close sun, giving the same answer with shadows due to the sun location, and we experience corpuscular sun rays here with no sign of parallel sun rays, so defiantly moves towards flat earth.
Anyway I know the test I do will finish any arguments as if we live on a globe the fishing line "MUST" drop under the water surface due to earth curve, so even with your (catenary of the fishing line) this will drop the line into the water and help the globe model, so if I find the fishing line above the water "At all points over the 2 mile", even with the line drop (not much at 200lbs tension), then the answer is the water is level & flat & horizontal, and the earth is also flat.
Can you help me please with maybe drawing it for me and sending a file over I can look at, as man o man you guys are good as I have no idea how to do it lol.
Thanks heaps
Tricky
