10-08-2024
11:30 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-08-2024
11:30 AM
Is that an OLE, or an attached image? On what layer is it on?
Attached , EV-Medium and yes it is on
What are you trying to push it behind?
Everything
What if you pull everything else forward?
Does not work once the image has pushed once
How do you know it is failing, is it just when you plot? Or a display that a REGEN or REGENALL will correct?
Regen and I imagine plot but not sure
Or a change to your hardware acceleration settings needed?
Your exact AutoCAD year version as listed in the program's ABOUT command is...?
Autocad Architecture - 2024 - 8.6.52.0
Your OS is...?
Windows 10
