pendean
en respuesta a: russellGCS4G
@russellGCS4G wrote:
...Is there a display order just for images/attachments?
We can't see what you see: share your DWG file with the image in it here please.
Is that an OLE, or an attached image? On what layer is it on?
What are you trying to push it behind?
What if you pull everything else forward?
How do you know it is failing, is it just when you plot? Or a display that a REGEN or REGENALL will correct?
Or a change to your hardware acceleration settings needed?
You exact AutoCAD year version as listed in the program's ABOUT command is...?
Your OS is...?
