OK, for what it is worth, I think I have found the reason that the polylines in my problem drawing will not convert using CONVERTPOLY.  I made a dxf file containing one of the problem plines and one of the problem plines that had been exploded and then reconstructed with PEDIT.  The problem pline contained a group code 70 (bit coded polyline flag) and when I removed this code in the dxf and loaded it back into AutoCad, the CONVERTPOLY command works properly.  I am not sure how to correct this problem, but as long as I don't run into drawings from the same source, I hope I don't have to.
