Chad_Trowbridge
285 Vistas, 3 Respuestas
Tab key and snaps AutoCAD 24
I just installed and started using AutoCAD 24 and I am no longer able to cycle through Osnaps using the Tab key.  Please help.
paullimapa
en respuesta a: Chad_Trowbridge
Have you tried Resetting AutoCAD 2024 to defaults?
https://help.autodesk.com/view/fusion360/ENU/?caas=caas/sfdcarticles/sfdcarticles/How-to-reset-AutoC...
Is it the same if you download & install AutoCAD 2025?
Paul Li
IT Specialist
@The Office
pendean
Did you remember to actively turn on SELECTION CYCLING first and ensure it is running @Chad_Trowbridge
I was able to isolate and replicate the issue and it was being caused by an add on software (CADworx).  The problem has been reported to their development group.  Thanks for the replies.
