10-06-2024
03:32 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-06-2024
03:32 AM
What you mean is lineweight, not thickness. "Thickness" is up off the page in the Z direction.
Some of your Polylines have non-zero width, which will override the lineweight setting. If you want the appearance to be controlled by the lineweight, make all Polylines have a global width of zero. You can select them all collectively and fix that for all in the Properties palette:
And set the PLINEWID System Variable to zero, so that subsequently-drawn Polylines will have it that way. That is set at 0.05 in the drawing as posted, and the Polylines I checked had that, so they were apparently drawn with that setting in place.
Kent Cooper, AIA
