leeminardi
en respuesta a: JoelMckone
It's a bit clumsy but since you need two vertices that are prependicularly aligned between the two parallel lines you can add a couple of construction lines to be referenced by the align dimensional constaint and then freeze the construction line layer.
For example, in th eimage below the red lines have a perpendicular constraint while the magenta lines have a collinear constraint.
The d7 and d11 constraints are to the endpoints f the red lines.
These constraints remain appropriately aligned when HLong is changed.
Freezing the layer hides the construction lines.
lee.minardi
