JoelMckone
295 Vistas, 2 Respuestas
Parametric Dimension
While I have used parametric dimensions in Inventor, I am  trying then in Autocad  (2025) for the first time.  The problem I have is I can't seem to do perpendicular dimension to 2 parallel sloping lines.  I managed to get it to work by changing the UCS to align to the slope but when I change a dimension, the dimension no longer aligns to the slope.
For example if  I change d5, then d11 and d7 do not measure the true perpendicular distance.
Etiquetas (2)
Etiquetas (1)
