darrenJS3P9
329 Vistas, 5 Respuestas
Paperspace/Modelspace zoom/scale resizing problem - Autocad LT2024
Good Morning Everyone,
I have a issue that I cant seem to find a solution to. In Paperspace, i have created a viewport, then created a layer (in paperspace) and dimensioned the view. Accidentally, i clicked into the viewport and changed the zoom. The problem i now have is that i cannot find a way of re-aligning the view of modelspace to match the layer in paperspace.
I hope this question makes some sort of sense and there is a simple way of resolving this. I have attached a screenshot, and to explain, the dimensions (on a layer in Paperspace) should line up with the centres of the red squares inside the (purple) viewport (showing modelspace) and that is what i am trying to achieve.
Many Thanks in advance
Daz
cadffm
en respuesta a: darrenJS3P9
I would ask why you have objects which have to match modelspace objects, but that'S your thing.
Take a look to command ALIGNSPACE
Sebastian
darrenJS3P9
en respuesta a: cadffm
Hi, Thanks for the info regarding ALIGNSPACE. Unfortunately that is part of express tools, and not available in 2024LT so i cannot use it.
Daz
cadffm
Sorry,
you are posting in AutoCAD (not LT) board and I oversaw that detail in your topic.
AutoCAD LT board -> Next time - Click!
LT-Answer, beside to find a similar tool for LT2024+
Move your paperspace content to the modelspace-objects!
Use command MOVE in paperspace, that's all.
Sebastian
darrenJS3P9
My apologies. First time posting, i didnt think to look for a seperate LT forum.
Daz
cadffm
set up the proper vierwport scale,
adjust the model view / position,
back  in paperspace - use MOVE
Sebastian
