ictsupportGGWFW
336 Vistas, 4 Respuestas
Hatch scale changed in view port
[Post moved to new thread and Title modified by CGBenner 9/18/24]
pendean
en respuesta a: ictsupportGGWFW
@ictsupportGGWFW wrote:
HATCH SCALE CHANGED IN VIEW PORT
Not enough information: Is your HATCH annotative? That might do it. Otherwise... elaborate in more detail and share a DWG file with this issue present please.
CGBenner
@ictsupportGGWFW Hello, do you still need help with this question?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
1. Select Viewport: In model space or paper space, click the viewport for which you want to change the raster scale.
2. Scale Settings: Right click and select "Properties". Alternatively, you can go to the "Viewport" tab from the "Ribbon" menu and find the "Scale" section.
3. Changing Scale: Select or enter the scale you want in the "Standard Scale" or "Custom Scale" section in the properties window.
4. Update Viewport: Make sure the viewport is updated after making your changes. Resize the viewport if necessary.
Make sure that the changes made are saved.
Enjoy your work.
CGBenner
Chris Benner
