dan4UYYZ
326 Vistas, 4 Respuestas
Multileader Leader Connection
I have four lines of text in my Multileader, has any one figured out how to underline the second line? My only choices are underline top and bottom line. Would be helpful if anyone has a solution.
Thank you,
cadffm
en respuesta a: dan4UYYZ
I think there is no solution, Acad offering two options, that is all.
Ever tried to set up your own custom BLOCKs with Attributes for this case (instead of MText option)?
Sebastian
dan4UYYZ
en respuesta a: cadffm
Thank you for responding. I figured that was my only option was to create blocks with attributes. Hope someday Autodesk will add more than just underline top or bottom of text line in their multileader. Thank you so much for searching for a solution.
Dan
ВeekeeCZ
Well, since you have 4 lines, you can use the middle of the text option...
dan4UYYZ
en respuesta a: ВeekeeCZ
Hi
i also have one question if there is a lisp routine or command that I can match properties of one multileader to another multileader by angle rotation?
thank you
dan
