- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Do a little Searching. For example, >this< may have something you can use. The link to my Property.lsp seems to be broken, but I'm attaching it here. It does this kind of thing:
either as you draw boundary Lines and Arcs, or to add to already-drawn ones.
But it does both bearing and distance [for the chord in the case of an Arc, along with radius and included angle and length along the curve] -- not a choice of which. Those choices could be split out as separate commands.
It's designed for feet, but could be modified for metric use easily enough. And the PROPERTY linetype it calls for is a custom one of ours -- you'll need to choose a linetype that you have.
Also, I expect the Map and/or Civil overlay versions already have such capabilities.
