- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hello @paul_margerie
Maybe there's something wrong in the Configuration.
Would you mind sharing both of your plotter configuration files (from ACAD 2022 and ACAD 2024)?
And maybe your drawing too (you can delete all objects in model space and paper space, just leave the layout you would like to print.
If you don't know where to find your plotter config files, just publish your drawing as eTransmit (it will create a zipped file with everything needed to open the drawing). You can also open the resulting ZIP file and just copy the plotter config (*.pc3) files.
One question: Which versions do you use in both of your AutoCAD installations - Imperial or Metric?
If they differ, maybe there's some "translation" issue from Meters/Millimeters to feet/inches.
Windows 10 Pro 64-bit | Civil 3D 2024 / Revit 2024 (64-bit EN)
ASUS Maximus Hero VIII / Intel QuadCore Core i7-7700K / EIZO FlexScan EV2411W 24" + EV2416W 24" / 64 GB Corsair Vengeance LPX (4x 16 GB) Dual-Channel DDR4 / 12 GB ASUS GeForce RTX 3060 OC V2
Windows 10 Pro 64-bit | All Autodesk Products 2023 + 2024
HP ZBook Fury G10 / Intel Core i7-13850HX / 3x Lenovo 24" / 128 GB RAM / nVidia RTX Ada 3500
