AllenJessup
en respuesta a: cadffm
@cadffm wrote:
My question:
>>"If so, how can I activate this option or work around this issue?"
Thanks in advance for your suggestions!
If I understand your question correctly. In the CTB set Lineweight to Use object Lineweight. This will default to whatever is set for the entities Layer as long as the entity Lineweight is set to ByLayer. Then you'll get whatever the Lineweight is set to in the layout.
Allen Jessup
CAD Manager - Designer
