yairMSKTU
444 Vistas, 6 Respuestas
when i click a letter it shows me the wrong command
usually x showed me explode,  m showed me move, r showed me rotate ETC...
suddenly today x shows xattach, m showes something (dont remember), ro shows round (fillet) ETC...
how to fix it ?
imadHabash
en respuesta a: yairMSKTU
This usually happened when someone edit your acad.pgp file. You can check it from ALIASEDIT command.If you edit the PGP file while the program is running, enter REINIT to use the revised file. You can also restart program to reload the file automatically.
Imad Habash
yairMSKTU
i doubt anyone touched it.
i tried to restart pc multiple times and didnt change anything.
imadHabash
AutoCAD has search paths that read from his data.check if any CAD files lately copied near from those trusted paths.
Imad Habash
yairMSKTU
and if pgp file was changed,  how do i change it back ?
imadHabash
Nobody will guaranty that you will get back your normal work since you don't know the exact and real reason of the new CAD behavior. You can edit again your Acad.pgp file OR reset AutoCAD to default settings.
Imad Habash
pendean
