pendean
en respuesta a: aaronjames4123
@aaronjames4123 You set up and used constriants correctly in the first imag (see those boxed icons around your shape?), you forgot to do so in the second one, so those are not really the same.
@aaronjames4123 wrote:
...I added the constraints to replicate what my old settings used to be like.  When I was using autocad a few days ago, it would function like the green one without needing to add grips.  That's what I want to restore....
You've not provided such an image or DWG file, so for us over here will have to say you did not create them the same way at all. Sorry.
Show your work, share your DWG from the first image, and a DWG from this last reply where to state you "fixed it", it might be easier to help you out that way.
