353 Vistas, 5 Respuestas
New monitor, New problems. Dialog box too far
I just upgraded from a computer monitor to a TV.  I adjusted a lot of the setting and fixed a lot of the issues.  One main issue that I cannot resolve is that dialog boxes that appear (selecting a line: stretch/lengthen, polyline: add/remove...points, etc.) are not too far from the cursor for me to select them.  When I try to select lengthen on at a point, the box disappears before I can get the cursor to select one of the options.  I've tried searching under options and various other places, but have not had any luck.  Please help!
paullimapa
en respuesta a: Anonymous
Did you try turning off Hardware accelleration?
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
en respuesta a: paullimapa
thanks for the tip, didn't fix the problem.  I am considering upgrading my video card to help with some resolution issues though.
paullimapa
If you do purchase a new graphics card, make sure you get one that is certified by Autodesk for the version of AutoCAD and OS.
 http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
Paul Li
IT Specialist
@The Office
pendean
Can you show us a screenshot or two? Or even a video (SCREENCAST is free to use from Autodesk).
en respuesta a: pendean
Will do.  When I get a spare moment I'll record and upload the problem.  Thanks!
