It seems, buddy, that you do not understand what a block is. A block is a separate small drawing. And in your large drawing, many references (BlockReference) to it are inserted. If you edited the block, then all its BlockReferences will look different. The only thing you can do is to explode the block, edit the objects and assemble a new OTHER block under a different name.
BTW, To simplify the conversion of separate BlockReference into new blocks, there is the AsmNew command from the AVC Assembly plugin, which will itself come up with a new name for the new block.
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
