- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hey everyone. I have a little problem here and really need your help. I have a couple drawing in BricsCAD with original scale (1:1). On the other hand, I have a same drawing in AutoCAD with original scale (1:1). The problem is, I try to copy the AutoCAD drawing to the BricsCAD but, the scale is not 1:1. However, the scale become small in BricsCAD. Hope you guys can guide me with this problem. Thanks in advance. in BricsCAD
in AutoCAD
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
1. Make sure it is the same size.
Use command DIST to measure a length in both
Do you think they are drawn in same units?
2. Does it works the opposite way, from BCAD to ACAD?
If so, check your BCAD InsunitsScaling setting
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@alfinmuharrram97 schrieb:
what should i do next?
So the opposite way works, from BCAD to ACAD?
Okay,
if you are not familiar with a feature/command/sysvar, learn more about it, press [F1]
But this help is a bit confused, so remember the current value (1 ?) and try to use value 0 (means off)
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You are talking about clipboard action (ctrl+c/ctrl+v), or?
If not, tell us your way " try to copy "
and draw in line with length = 1 in Acad
how long is it after pasting in Bcad?
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
What if you xref the Briscad dwg into Autocad? Does the scale look right then?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@alfinmuharrram97 wrote:... The problem is, I try to copy the AutoCAD drawing to the BricsCAD but, the scale is not 1:1.
Might want to consider these links:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
