Without lisp, not that I know off,
You have to recreate them in the order that you want them to appear and delete the ones that are in the wrong order.
With Visual lisp you can get the summaryinfo of a document, you can read, set and create custom properties with visual lisp, so in a way you can 'set' the correct order there. But that would be more complex than doing it by hand, it would also not be interactive unless you add some dcl and a sorting routine.
