pendean
en respuesta a: patrickanderson3E6PW
@patrickanderson3E6PW wrote:
... trying to modify the code for the GAS linetype to say PHASE 1. I have it working but I can't figure out how to adjust the line spacing as the line starts again in the middle of the word PHASE 1...
So if you use GAS in the same file right next to it, that has no issues? Or is the break between PHASE and 1?
OR... Can you show us what you mean please?
And did you do more than just replace one work with another?
But first... is this a STYLE setting fix in the DWG file? The linetype uses STANDARD, and that might be different between your DWG files.
