cadffm
en respuesta a: ckeipp
>"Any suggestions and assistance would be greatly appreciated! "
Just the same you can read in your links.
.dwg (and others) extensions link to aclauncher.exe
doubleclick to a .dwg
make sure SDI=0 in this instance
close
doubleclick to a .dwg from explorer
If it is still not working.
Admin rights, deinstall and install new - the newest version.
Questions: Does it work well inside AutoCAD?
Open your product, use OPEN command to open two ore more .dwg files. Does it work?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Double-clicking-a-...
Sebastian
