kjernelo
214 Vistas, 1 Respuesta
Wireframe 2d is messed up
Just downloaded AutoCAD 2025 and I seem to be having major problems using the wireframe 2d view.
Regular lines disappear as soon as I've drawn them and curved lines cause these black fields to appear!
Selecting all shows me all lines are still there, just not visible. Also, the grid is turned on, but invisible.
When adjusting the view using the view cube I can se all lines and the grid and everything I am supposed to see for a brief moment while the view adjusts, only for it to disappear again.
The other visual styles seem to work better (I think), but I really need the wireframe to work.
I can't find anything like this being solved on here so I'm thinking maybe I should just try to delete and reinstall the whole program?
Valentin-WSP
en respuesta a: kjernelo
@kjernelo ,
Consider checking the requirements or switching your DirectX version:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
