pendean
en respuesta a: Lingwisyer
@Lingwisyer Thanks for the files. It appears you are ignoring the experienced advice from @cadffm
1) Hatch patterns provided by Autodesk have literally not changed since the year 1991.
2) Your 2010 file contains a custom created-by-someone hatch pattern they chose to call ANSI31
3) Your 2025 file contains the true from-Autodesk hatch pattern that is in AutoCAD called ANSI31 that we can all match, in my case, AutoCAD 2022-23-24-25.
So... how would you like to proceed? I suggest your 2010 hatch be renamed something else so you can keep using it, copy that patterns into your 2025 setup with that new name. too.
