Lingwisyer
1156 Vistas, 14 Respuestas
Hatch not matching definition
Hi all,
I have one computer running aCAD2010 and another running aCAD2025LT and have run into an issue of hatches not matching. In the image below, the blue hatch is ANSI32 from 2010, and the yellow hatch is ANSI32 from 2025LT. Upon measuring the lines, 2025LT matches the hatch definition while the 2010 does not. Spacing ratio of 1:2.0, expected, vs 1:5.3... Other than the scale difference between acad.pat and acadiso.pat, is there anything that might be causing hatches to not match given the spacing is not even the correct ratio? I checked the two .pat files and the definitons are identical.
Ling.
Etiquetas (1)
Etiquetas (1)
