trusty110
381 Vistas, 4 Respuestas
Tool Pallet import
i have a drawing (.dwg) created on an old pc with AutoCad 2005.  Can I open it with 2025 and import the old Tool layout pallet menu?
pendean
en respuesta a: trusty110
DWG files do not store Tool palette (TP) information to "import" from, but you can create a new TP in AutoCAD2025 from it's block content for sure using ADCENTER command for example, or manually drag-and-drop to a new TP as well. Give each a try.
trusty110
en respuesta a: pendean
thanks much. are you saying that there is a file created in the 2005
version with the extension '.tp' that may be imported to the 2025 version?
ie, I can open the drawing in 2025 version, then imported the old tool
template?? thanks again.
pendean
trusty110
if you think it's too good to be true (or too easy)... you're right.
