Patchy
en respuesta a: Anonymous
Acadiso.dwt is a template to start a metric drawing.
Use STARTUP cammand and set it to 0.
Make a new drawing and you have choice Metric or Imperial.
Since you already started Imperial unit drawing, use command -DWGUNITS and change your drawing to metric (answer yes to have your drawing scaled)
Then make a new drawing, start with Acadiso.dwt; then save as acadiso.dwg and drag & drop it into your existing drawing, the dimension will appear.
