- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi all,
Im using a student version of AutoCAD 2016. I need to Change a setting in my dimensions manager to ISO-25 for a drawing im doing, but i only have the standard option available. Could anybody tell me why this is?
Many Thanks
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I am very new to all of this, could you tell me what the difference is? Just out of interest.Thanks!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Acadiso.dwt is a template to start a metric drawing.
Use STARTUP cammand and set it to 0.
Make a new drawing and you have choice Metric or Imperial.
Since you already started Imperial unit drawing, use command -DWGUNITS and change your drawing to metric (answer yes to have your drawing scaled)
Then make a new drawing, start with Acadiso.dwt; then save as acadiso.dwg and drag & drop it into your existing drawing, the dimension will appear.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous
This Autodesk 2016 Templates site has information that you can read over each of the templates.
The site has a brief explanation of available templates.
Were you able to test the ACADISO.DWT template?
Sarah Emmsley
Technical Support Specialist
