@Tomislav.Golubovic wrote:
Why explode dimensions when you can turn the extension lines OFF in the properties?
Absolutely.  And if you use a routine like DimExtLineToggle.lsp with its DET command, >here<, you can turn off [or back on] either extension line without needing to know which is 1 and which is 2.
Kent Cooper, AIA
