07-02-2024
11:04 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-02-2024
11:04 AM
What version are you using? In older versions, you could just hit Enter to <select all> objects as boundaries [without highlighting] in either TRIM or EXTEND. In newer versions, that operation is the default [unless you turn it off with the TRIMEXTENDMODE System Variable], and you need to tell it if you don't want everything, i.e. if you want to select only certain objects.
Kent Cooper, AIA
