- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I'm trying to modify the pens from 250 on up by using the same settings that are in the ACAD.CTB file. I'm trying to get the same shaded values for grey scale solid fills. My NEW.CTB file was copied from a project CTB file which I modified to have the same values for pens 250-255. Unfortunately, they don't plot at all in my drawing. Any ideas? Thanx
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Share your dwg as well
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
zip the ctb along with sample dwg and post that
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@dbanaszak wrote:See attached.
And the DWG file? Or at least a relevant portion, titleblock/client info is not needed (even though it is there in the PDF).
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
your PDF is not the result of plot C3.0 with CivilShade.ctb
Plotting with this .ctb will hide ALL Objects with color 250-255
because they are set to print 0%
So it isn't set to the same as the original acad.ctb (also Greyscale property is different for 253)
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
offtopic
Please, Next time: Set the sample Layout current and set pagesetup proper to what you are talking about - and what you used for the sample plot/pdf, many thanks from all helpers ![]()
edit
Have you managed to solve this problem now or do you still need support? @dbanaszak
Sebastian
