j.palmeL29YX
en respuesta a: jaskiratspanesar
@jaskiratspanesar wrote:
To me, it seems like some dimensions are missing to draw arcs.
The opposite is the case: If we assume on the left site all arcs/lines touch tangetially, then one of the dimesnions (e.g. the 50° angle) leads to an overdimensioned/overconstrained geometry.
Attached an example which was drawn using constraints. I "ignored"  the 50° angle and got an full constrained geometry.
I you move the inserted image 200 to the right you can compare you image shape with the AutoCAD geometry. To reduce the discrepancies between both I changed the 96 dimension t0 95.
You can play with this file until you get the needed result, as example:
- change the 95 back to the initial 96 (double click at d6 and change the value) and see what happens
- add the 50° angle if you urgently need that value (you must delete one of the tangential constraints before) and see what happens.
- Play with changing other dimensions and or geometrical constraints. We (I) can not know how the shape should look at the end.
Jürgen Palme
