jarredmonday
2379 Vistas, 2 Respuestas
Sheet Set "Source File" not following Copied Drawing file.
When copying the master .dwg file WITH the .dst file into a new folder, the .dst "Source File" is linked to the master .dwg. I expected the "source file" to be updated when both files are copied together. Is there a setting in the SSM I am missing to be able to update the source file location ?
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Etiquetas (2)
